1. albie999's Avatar
    Hi, I am trying to add an NFC tag as a trusted device on my S7 Edge, however, in the Add a Trusted Device screen, NFC does not seem to be listed. When I click on Add Trusted Device, it only shows the devices I have paired via BlueTooth, and not an option to scan for an NFC Tag
    https://photos.app.goo.gl/dUrwec0NFN6klVIh1
    https://photos.app.goo.gl/O6IF794DFB5MDYDI2
    Any ideas? When I put the NFC tag against the phone, it bleeps so it can pick it up
    12-01-2017 06:32 AM
  2. 1122334455667788's Avatar
    I think I read somewhere that Google removed that option.
    12-01-2017 09:59 AM
  3. albie999's Avatar
    Oh, clever Google ... That's not helpful of them
    12-01-2017 10:04 AM
  4. 1122334455667788's Avatar
    And here is where I read it:
    Smart Lock originally supported NFC-based unlocking, but as of September 2017, the option has been deprecated. Users who have set up Trusted NFC tags can continue to use them, but they won’t be able to modify them or add new tags.
    From Digital Trends - https://www.digitaltrends.com/mobile...id-smart-lock/
    12-01-2017 10:10 AM
  5. Rukbat's Avatar
    You could probably use Tasker (with Secure Settings) to unlock the phone for the particular tag. (I usually don't recommend paid apps, but Tasker is more than worth the price.)
    12-01-2017 12:37 PM
  1. problems with web links in my emails
    By kuw in forum Android 6.0 Marshmallow
    Last Post: 12-01-2017, 10:11 PM
  2. What is IOThiddenmenu in my Samsung galaxy j1
    Last Post: 12-01-2017, 09:21 PM
  3. Recently my phone will randomly pull up an app in the app store.
    Last Post: 11-30-2017, 11:04 PM
  4. note edge shutting off will start back up if plug in why?
    Last Post: 11-30-2017, 11:03 PM
