1. jennlk's Avatar
    I just got a refurbished s7 edge on Amazon and it looks great. Now I need a sim card but not sure what kind and where to get one. I believe it uses a nano 4ff card. I currently am on Verizon prepaid on s3 but it has an embedded sim. I need to know what kind to get and if I can keep my same number. I've never done this before. Thanks!
    12-04-2017 08:21 PM
  2. B. Diddy's Avatar
    Are you planning to stay with Verizon, or are you moving to a different carrier? What's the exact model number of the phone? You can find it in Settings>About Phone>Model Number.
    12-04-2017 10:39 PM
  1. Adding New Panel to Home Screen on LG X Venture
    By Rsnyc in forum More LG Phones
    Last Post: 12-05-2017, 01:31 AM
  2. Replies: 1
    Last Post: 12-04-2017, 10:56 PM
  3. My location was turned off and i didnt do it...why is that?
    Last Post: 12-04-2017, 10:54 PM
  4. My phone is mute and i restarted it and all the volume is gone how do i fix it
    Last Post: 12-04-2017, 10:47 PM
  5. Help to remove?
    By GREGG DELFINER in forum Ask a Question
    Last Post: 12-04-2017, 10:30 PM
