1. markm75's Avatar
    I have an s7 edge 32gb with an external sd card installed and android 7 (actually 2 phones similar issues on both)..
    Constantly we run out of space on the internal.. very few apps installed as well
    In my case apps shows 22.96 used (but when i use cccleaner and view, that total inside shows 18 or so)..
    I only have about 4 apps larger than 300MB though yes, i do have 300 apps installed (a lot haha, mostly small tools)..
    Videos shows 2.89gb and pics 2.26 to internal.. i have photos and vids set to goto SD card which they appear to do so, mostly.
    When i drill into these though, i can see some that ended up internal.
    Cache wise i have around 900MB i could clear (i wish this could be automated).
    Any thoughts on space here or why videos/pics seem to randomly end up on the internal memory..
    Keep debating to go for an s8 64GB to avoid this, but something tells me we may end up in the same boat over time even on that platform.
    Thanks in advance for suggestions/ideas
    younggreenanne likes this.
    12-06-2017 02:24 PM
  2. markm75's Avatar
    I found one thing out.. i removed the sd card.. suddenly i had around 5GB more free space.. it seems it was classifying the sd stored photos and pics as local storage.. maybe a remnant of adoptable storage from before, though i thought i had wiped the phone at one point?
    12-06-2017 04:24 PM
  1. So - who's going to pick up a V10?
    By James Falconer in forum Honor V10
    Last Post: 01-26-2018, 07:54 AM
  2. Contacts, calendar' birthdays, anniversaries not showing up
    By rasputin01 in forum Samsung Galaxy Note 8
    Last Post: 12-06-2017, 04:14 PM
  3. How can I move my lock screen time to anywhere on the lock screen
    Last Post: 12-06-2017, 03:04 PM
  4. Problems with my Samsung galaxy S7 edge and straight talk
    Last Post: 12-06-2017, 02:00 PM
  5. A little black dot with a cross in the middle how to remove
    Last Post: 12-06-2017, 01:15 PM
Tags for this Thread
