Hi all, first time posting on here.
To start I have a Samsung galaxy s7 edge (SG-G935W8). I got this phone in October 2016. Recently the rear-facing camera went funky and all of my images taken with the rear-facing camera started having green/purple lines on them. I figured that it was the camera itself that had broken as the front facing camera still works. There are no signs of physical damage on the camera.
Note: The phones warranty is already voided as I had the device rooted at one point.
So after doing some research online I got this replacement camera.
Fast forward 1 week later and it arrived. Yesterday I took the device apart following a YouTube tutorial.
After replacing the old camera and closing the device back up I turned the phone back on. Opening the camera app this is the message I am now prompted with.
I took the device apart again and made sure the camera was connected and placed in there snugly. Reboot, and same message. I then proceeded to clear the cache and camera data from the application manager and reboot in safe mode. Same error.
I've watched a few other online tutorials to try and trouble shoot the "Warning: Camera failed." error. Some suggested tips were to use the MMI code *#7353# through the phone app but I am prompted with another error code.
From here I have no clue where to go. I tried messing around with network SIM card settings and resetting my network provider to Telus again, but that did not fix the issue with inputting MMI codes.
If I open the phone back up and put in the old camera the camera app opens and takes images with the green/purples lines.
At this point I have given up on the idea that I know what im doing, if anyone has any experience or idea on how to solve this issue that would be wonderful.
Thanks, Caden
