1. SILVERSLEEPER484's Avatar
    Hello, can someone please tell me what this 3/4 circle with a + button inside is. I have attached a screen show highlighted in yellow. I am on the AT&T network and can not figure what it means/what it is used for. I also tried to delete, but there does not seem to be an option.
    I was hoping someone here can tell me exactly what this is for.
    Thanks,
    Tim
    12-13-2017 11:44 AM
  2. Javier P's Avatar
    Hello Tim! That's the data saver icon. You can enable/disable this feature in the data usage settings.
    12-13-2017 11:47 AM
  3. SILVERSLEEPER484's Avatar
    Helllo Javier,
    Thank you very much.. Data Saver does that mean it is backing-up all of my photo's, video's and websites? If so does that mean it is constantly using my data so AT&T can charge me if I run out of my data limit?
    Tim
    12-13-2017 12:09 PM
  4. Javier P's Avatar
    This article will help you to understand how the data saver feature works.
    Android 7.0: Data Saver will prevent overages on cheaper plans https://www.androidcentral.com/andro...ss-data-saving
    SILVERSLEEPER484 likes this.
    12-13-2017 12:15 PM
  5. SILVERSLEEPER484's Avatar
    Javier, thank-you very my (Y)
    Javier P likes this.
    12-13-2017 12:58 PM
  1. Facebook links keep opening inside the app
    Last Post: 01-01-2018, 06:41 PM
  2. Why is some of my contact information missing?
    Last Post: 12-14-2017, 12:13 AM
  3. Pin to Screen
    By NickA in forum Samsung Galaxy Note 8
    Last Post: 12-13-2017, 08:07 PM
  4. How to backup galaxy s7 before activating galaxy s8?
    By Bmaria12 in forum Samsung Galaxy S8 & S8+
    Last Post: 12-13-2017, 11:41 AM
  5. My volume settings never save after I adjust them to the preferred level.
    Last Post: 12-13-2017, 11:31 AM
