    I have a problem in my s7 edge.
    Nowadays my phone often restart by them self. At least 2 times per day.
    i have tried to factory reset and the problem is still there.
    Can someone help me to fix it?
    Thanks
    12-20-2017 04:19 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Does it still restart in Safe Mode? https://support.t-mobile.com/docs/DOC-28008. If not, then some app you installed is causing the instability -- you'd have to uninstall apps one by one until the problem goes away.
    12-20-2017 11:42 AM
  3. pontiac005's Avatar
    Try wiping the cache and see if it helps. Also Diddy is right, it's probably a bad app.
    B. Diddy likes this.
    12-23-2017 12:39 PM
  1. S7 Edge Rooted phone TWRP flash fail
    By Android Central Question in forum Samsung Galaxy S7 edge Rooting, ROMs, & Hacks
    Last Post: 01-04-2019, 12:28 PM
  2. S7 Edge not responsive after shock
    Last Post: 12-20-2017, 03:08 AM
  3. Why my galaxy j500h start restarting
    Last Post: 12-20-2017, 01:46 AM
  4. Fastboot mode bootloader help s6 edge
    By wajahatandroid in forum Samsung Galaxy S6 edge
    Last Post: 12-20-2017, 12:23 AM
  5. S7 Edge Rooted phone TWRP flash fail
    Last Post: 12-19-2017, 05:52 PM
