1. madman x's Avatar
    i bought a pair of wireless headphones and i need a phone that can handle running them for long periods of time
    looking at a galaxy s7 edge... i heard that it has problems with bluetooth draining it's battery though, is that true?
    i will be using the headphones for 4-5 hours at a time
    is this phone good enough? how long can i listen to music with said headphones ideally?
    THANKYOU
    12-30-2017 04:56 PM
  2. Rukbat's Avatar
    Bluetooth is a radio transmitter, so it uses a lot of power. Get a powerbank, so whatever phone you get will hold up longer. (They make 30,000 mAh powerbanks, about 10 times the power in a phone battery, so one will last 10 times as long as the phone's battery. [Just don't let either the phone battery or the powerbank battery discharge to less than 40%.])
    12-30-2017 10:49 PM
  3. madman x's Avatar
    interesting. this is new to me.
    so do i keep the phone and powerbank connected in my pocket all day?
    12-31-2017 12:48 AM
  4. Ipse_Tase's Avatar
    I use a BT headset EVERY DAY on conference calls (maybe 5-6 hrs) and do not see a significant drop compared to wired headphones. I also have a smart watch connected 24/7 and still my main battery drain comes from my voice calls and email.
    Hope this puts your mind at ease.
    01-06-2018 12:51 PM
  5. gavo360's Avatar
    I stream Bluetooth in my a car an hour or so a day and don't notice any significant battery drain from one hour of usage. Is the audio you are playing stored locally or streaming? I wouldnt expect 4-5 hours of bluetooth to kill the battery especially if the screen is off most of the time.
    01-06-2018 04:18 PM
  1. LG G5 battery problems
    By brianmccuk in forum Ask a Question
    Last Post: 12-30-2017, 11:03 PM
  2. Working example for audio and video streaming between two Android devices
    Last Post: 12-30-2017, 05:30 PM
  3. Android Auto not compatible with Samsung Galaxy S7 Edge?
    Last Post: 12-30-2017, 03:46 PM
  4. Huawei not seeing S7 hotspot
    Last Post: 12-30-2017, 03:16 PM
  5. Samsung galaxy a5 pink purple and blue screen
    Last Post: 12-30-2017, 01:13 PM
