    hello i am from pk i bought Samsung s7 edge g935fd but its not dual sim mean the sittings says fd and in sittings it shows two imeis but others apps and back glass says its g935f actually android marshmallow 6.0.1 is already installed but the device is custom and imei is changed and can not be updated officially what if i install nougat 7 g935f firmware manually by odin is that will risky or not i mean the imei and baseband will remain safe...please answer...
    01-05-2018 11:20 AM
  2. Rukbat's Avatar
    Does it have 2 SIM slots, and are they both working? If yes, flashing the FD firmware should work. (The firmware in it could be corrupt.) If it doesn't work in both slots, or it doesn't have 2 slots (it would have one for the SIM card and the second for the SD card if ir was the F), I'd return it. The FD costs more than the F, so if you paid for an FD, you were cheated.
    01-05-2018 02:55 PM
  1. When will samsung release the patch allowing all lower grade bluetooth to connect to s8?
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 01-10-2018, 02:53 PM
  2. Just got a Pixel 2. Unable to send SMS messages from USA to Australia.
    By hawthorngirl in forum Google Pixel 2 & Pixel 2 XL
  3. how to display time on locked screen in j5 prime
    By Android Central Question in forum Samsung Galaxy J Series
    Last Post: 01-06-2018, 12:44 AM
  4. Software Update
    Last Post: 01-05-2018, 10:40 AM
  5. samsung note 8 was hanged and could not switch off
    Last Post: 01-05-2018, 09:42 AM
