    Edge 7 screen rotate not working, icon missing from settings pull down menu, can't find in settings or anything using "sreen rotate" or 'portrait lock". Anybody have an update on this missing functionality
    01-26-2018 12:40 PM
  2. chanchan05's Avatar
    Just to be sure, you've checked the second page on the pull down menu and the edit option to see the hidden toggles?
    01-26-2018 02:00 PM
  3. squirple's Avatar
    I believe it usually says either "portrait", a rectangle with a little lock inside or "screen rotate", a diagonal rectangle with bendy arrows on each side.
    Was it in a spot before & vanished or you haven't been able to find it at all?
    01-26-2018 02:04 PM
  4. Rukbat's Avatar
    Pull down the notification bar, then edit the icons. About half of them don't show - you have to choose which ones to show, and "rotate" may be one of the ones off the normal bar. Choose an icon you'll never need (how often do you turn NFC on and off? or reading mode?) and replace it with the rotate icon - if you're going to change that. Otherwise, just show all the icons, tap the rotate icon and your screen will rotate from then on.
    thecomicbookandme likes this.
    01-26-2018 03:49 PM
  1. Replies: 7
    Last Post: 12-20-2020, 02:33 AM
  2. samsung galaxy S7 isnt working cant see screen cant see anything
    By Android Central Question in forum Samsung Galaxy S7
    Last Post: 01-26-2018, 05:28 PM
  3. Trying to transfer images on samsung s8 plus, do not get move option
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 01-26-2018, 04:11 PM
  4. My screen is very unresponsive
    Last Post: 01-26-2018, 01:15 PM
  5. mistakenly block myself into sending paid text Samsung s6 Edge
    Last Post: 01-26-2018, 09:44 AM
