Shop HP’s Memorial Day Sale:Save up to 61% on PCs and more!
  1. bbb bbb's Avatar
    After each call, I get a blue screen showing the phone number I called, or that called me, and an option to block.
    I don't know how or why this is appearing on my Verizon carrier, s7 edge.
    I've not installed any new apps, and disabled almost every app notification
    I can post a screen shot if that is an option
    Any help at removing this blue screen is much appreciated
    Attached Thumbnails weird blue screen (not of death) after each call-phonenumber.jpg
    02-05-2018 03:31 PM
  2. Javier P's Avatar
    Welcome to the forums. What happens if you tap on the three dots included in that blue popup? I remember a similar issue and I think for some people the culprits were apps like Viva video, UC browser ...
    Moeed 135 likes this.
    02-05-2018 03:53 PM
  3. bbb bbb's Avatar
    figured it out.. it was the Vault app.
    Javier P likes this.
    02-05-2018 04:51 PM
  4. Javier P's Avatar
    Excellent! Glad you figured it out and thanks for the follow app! It'll be very helpful for other users with a similar problem. See you around the forums.
    02-05-2018 04:59 PM
  5. Moeed 135's Avatar
    I was having similar issue.I checked the forum and for my case, it was Viva Video. Thanks for helping !
    02-24-2018 09:58 AM
  6. daniel beezley's Avatar
    Hi this is happening to my phone to? I also have vault app what did you do to stop it ?
    Thanks
    02-24-2018 03:35 PM
  7. Dragi Popovski's Avatar
    After reading all of the comments, I started searching the apps that have lots of adds. For me, it was the vault. Went to settings of vault, on the bottom, under others, I turned off call reminder. I hope this helps.
    03-14-2018 11:39 PM
  1. Why will my torch not turn on but button won't turn off
    Last Post: 02-05-2018, 03:18 PM
  2. Is it possible to recover a camera view I wanted to take a picture of?
    Last Post: 02-05-2018, 03:16 PM
  3. Not sure which phone to get next?!
    By splodge2003 in forum Ask a Question
    Last Post: 02-05-2018, 02:00 PM
  4. cant answer call via message+ on sm-t350
    Last Post: 02-05-2018, 12:39 PM
