    I have an artist friend that does an Illustration/Portrait of a picture of you that has to be HD PRINTABLE.
    So can I send a picture from my gallery that was taken from my S7Edge phone?
    02-11-2018 05:44 AM
  2. chanchan05's Avatar
    Hmm. It would depend exactly I think on what he means by HD printable.
    If he means it can be printed in an HD size like 1080p, then yes, the 12mp photos from an S7 is more than enough.
    If he means HD printable as in possibly referring to a lossless format like TIFF, JPEGXR or something else, then no the basic photos from an S7 can't be used. You may have to take pictures in RAW format then convert.
    02-11-2018 06:32 AM
  3. natehoy's Avatar
    Neither I nor Google are aware of a standard called "HD Printable".
    The only technical definition of "HD" is for TV - and that means anything over 720p (1,280×720). But that's under 1 megapixel so I doubt they mean TV-level "HD".
    You need to know how many pixels they want. At highest resolution in 4:3, the S7 Edge camera takes 4032x3024 pixel images. So it can print an 8x10 image at approximately 375 PPI with no scaling (just a little cropping) or a 56-inch by 42-inch print at 72 ppi. Of course, the standard JPEG format is hardly lossless, so as chanchan05 said to make the most of the camera if they really want to use all the pixels, you're going to want to set your phone to save RAW images and then convert (or have them convert) them to a lossless format.
    02-23-2018 02:55 PM
  1. Why is my LG Aristo locked on master reset reboot screen
    Last Post: 02-11-2018, 10:23 PM
  2. My navigation stopped on my Android so it doesn't go back
    Last Post: 02-11-2018, 10:21 PM
  3. Galaxy S4 won't turn on
    Last Post: 02-11-2018, 10:17 PM
  4. Wet Charging Port Warning Going On & Off
    By Joshua_Muldoon in forum Samsung Galaxy Note 8
    Last Post: 02-10-2018, 04:12 PM
  5. can I install android on my samsung galaxy book?
    Last Post: 02-10-2018, 03:55 PM
