1. markeee_mark's Avatar
    Tile GPS locators are great, but the Tile app requires that it is 'constantly' on and running in the background for it to be most effective. I force close my apps (via the menu button) at least 10 times a day to cut down on battery drain, but I would really like the Tile app to stay on. Any suggestions on how I can keep this app running in the background regardless of the force close option I normally do daily?
    Thanks in advance!
    03-21-2018 05:44 AM
  2. markeee_mark's Avatar
    Bueller. Bueller. Bueller.
    Jason Us likes this.
    03-23-2018 01:08 AM
  3. yostevo's Avatar
    Press the button to choose from open apps (the same place you choose close all apps) but choose the menu button and choose lock apps. Lock the tile app.
    10-08-2018 02:52 PM
  4. Jason Us's Avatar
    Same deal. I shut down apps all day long to conserve the battery and just cause I have OCD. Was super angry to learn the dang tile doesn't work with a **** if the app isn't turned on!!! Damn. Why didn't they build it as a service ???
    08-01-2019 05:39 PM
  5. AlbertoGSr's Avatar
    Thank you. It works. Samsung Note 8. Even if I turn off the phone, the tile app still open and lock. Thanks again.
    08-12-2019 11:09 AM
  1. White on white messages
    Last Post: 04-01-2019, 08:13 PM
  2. Galaxy S9= keep getting message "WiFI Disconnected" while at home
    Last Post: 03-20-2018, 06:06 PM
  3. Can't convert .Avi to play on Moto e4
    By esjayy in forum Moto E4 & E4 Plus
    Last Post: 03-16-2018, 04:07 PM
  4. Replies: 1
    Last Post: 03-15-2018, 03:02 PM
  5. Droibox MXG blue flashing led won't turn on.
    Last Post: 03-15-2018, 03:01 PM
