1. Will3101's Avatar
    Hi all, I recently purchased the phone from ebay as a refurbished unit. Everything works fine but when i try to use google pay it reports for security reasons it cannot load as the device may be rooted. I have done some research and used apps to check the knox status (0x0) and root status, which it hasn't been rooted. Doesn't make any sense any help would be appreciated. Thanks
    P.S I have tried a full factory reset of the phone as well.
    04-08-2018 01:03 PM
  2. neo158's Avatar
    This is a known issue with Samsung devices, I'm not sure if Samsung released an update to fix it or a workaround was published. Might be worth checking on XDA to see if they have a resolution if no one here has had this issue.
    04-08-2018 01:32 PM
  3. Will3101's Avatar
    Thanks for the reply I will certainly look on XDA as well hopefully someone has a fix
    04-08-2018 01:38 PM
  4. Will3101's Avatar
    Just an update here I have realised the phone is still running 6.0.1 marshmallow but the update software button doesn't do anything and also I tried to update with smartswitch which also reports the phone is up to date.
    04-08-2018 02:14 PM
  1. Numbersync issue on GalXy S9+ & smartwatch
    By jgreg02 in forum General Carrier Discussion
    Last Post: 06-06-2018, 11:30 PM
  2. Keep WiFi on when turning on airplane mode
    By THEPRFCT10 in forum Samsung Galaxy S8 & S8+
    Last Post: 04-11-2018, 11:35 PM
  3. S9+ on Sprint
    By kdmea in forum Samsung Galaxy S9 & S9+
    Last Post: 04-09-2018, 07:00 PM
  4. How do I undo an preinstalled app update on my samsung phone?
    Last Post: 04-08-2018, 04:10 PM
  5. Camera isnt working properly
    Last Post: 04-08-2018, 01:35 PM
