1. daisy-d52's Avatar
    i have tried to hard reset my galaxy s7 edge to reset back to factory settings but when i go into recovery mode and press reset to factory settings it doesnt go onto next screen a message at the bottom of the screen says that this device cannot be reset back to factory settings.
    Can anybody help with with problem please.
    04-28-2018 09:23 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Is there a reason why you want to factory reset it? Has it been malfunctioning?
    Are you able to remove your Google account in Settings>Accounts​, and then do the factory reset?
    04-29-2018 09:29 AM
  1. What is this booting problem for my Samsung s6 edge?
    By aishwarya chevuturi in forum Samsung Galaxy S6 edge
    Last Post: 04-29-2018, 09:47 AM
  2. Can I use a old MHL adapter for Galaxy S7 on a Galaxy S8?
    Last Post: 04-28-2018, 06:21 AM
  3. Cannot send emails from S7 using Outlook and BTYahoo
    Last Post: 04-28-2018, 06:00 AM
  4. Does Nox app player identify as a Samsung Galaxy S8?
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 04-28-2018, 01:35 AM
  5. Does Nox app player identify as a Samsung Galaxy S8?
