    Is pink line issue in s7 edge is very common or some users face it,Which one should i buy exynos or snapdragon?
    How to check that the phone dont have defect if i buy a used one?
    05-20-2018 09:18 AM
  2. Rukbat's Avatar
    I haven't seen the complaint here, so it's evidently not common. How do you check a used one? With your eyes, look at it. (If you're buying it online, make sure there's a decent return policy.)
    05-21-2018 01:06 PM
  3. monil's Avatar
    I got the pink line on SD last year. Fortunately, it was under Samsung warranty, so it was not an issue for me. When I researched at that point, it was a fairly common thing. so better get some protection/ warranty info to make sure its covered. Samsung will honor this and fix the issue within warranty.
    05-22-2018 08:14 AM
  1. cloud storage Ap fails back up Samsung 7 edge
    By Android Central Question in forum Samsung Galaxy S7 edge
    Last Post: 05-22-2018, 03:35 AM
  2. cloud storage Ap fails back up Samsung 7 edge
    Last Post: 05-20-2018, 05:32 AM
  3. Grey bar at the very top of my screen, Galaxy S7 Edge
    Last Post: 05-20-2018, 03:15 AM
  4. My S7 is not turning on but i can see the charge?
    Last Post: 05-20-2018, 02:28 AM
  5. Use Samsung Pay on rooted AT&T Galaxy S7 (Snapdgragon)
    Last Post: 05-19-2018, 07:29 PM
