1. Sheljo82's Avatar
    I factory reset my samsung s7 edge as i upgraded, i never had one problem before the reset. Gave the phone to my best mate first night after transferring data she goes to sleep it was on 70 % she wakes up its on 4% any ideas why this is happening as it was fine before?
    08-02-2018 05:21 AM
  2. methodman89's Avatar
    Open Settings, Battery usage, and see what is using it.
    08-02-2018 07:45 AM
  3. ggrr8t's Avatar
    Do you have Outlook on it? That killed my battery.
    08-03-2018 12:06 PM
  4. Rukbat's Avatar
    Also install something like GSam Battery Monitor to see what's keeping the phone awake at night. (If the mobile signal is weak where she is, that alone could be doing it.)
    08-03-2018 02:05 PM
  1. My phone is calling and being called by the same person at the same time
    Last Post: 08-03-2018, 12:49 PM
  2. How do I do a factory reset on a galaxy s 5 im locked out. O
    Last Post: 08-02-2018, 04:03 AM
  3. I have the same problem. Why does my camera icon have a small red dot on the top left corner.
    By Android Central Question in forum Samsung Galaxy J Series
    Last Post: 08-02-2018, 02:52 AM
  4. Replies: 0
