Why is my phone stuck on the recovery screen?!?
JordanRothstein
My Samsung galaxy S7 edge has been having the same problem, showing no command above the android update logo, however my issue is that my power button does not work. I dropped my phone and the power button was pushed in and with the phones design is a 250 pound fix that i deemed not worth it. As normally samsung has a button combination that turn the phone on.
My phone ran out of charge and normally you would use the volume button combination to turn it on, and has worked in the past, but today the Recovery screen popped up and I have no clue how to fix it. HELP!
Golfdriver97
Trusted Member Team Leader
Moderator
Dec 4, 2012
35,367
113
63
Welcome to the forums. Without being able to press the home button, you can't get out of the recovery screen. To leave the No Command screen usually requires pressing power and clicking volume down.
kirk781
