    I am trying to find a program that will back up my text messages so I can review them on the PC. Is there anything that will do this and also make it viewable on the PC? I want it to back up the pictures, etc in the MMS as well.
    Thanks
    11-12-2018 12:09 PM
  2. Rukbat's Avatar
    Backing them up backs them up as xml files, which may take you some time to figure out. (Once you do, it's not difficult to read them.) SMS Backup & Restore
    If you want them in human readable form (you can't restore them, though), try SMS to Text.
    11-12-2018 10:58 PM
  3. pontiac005's Avatar
    I'm using Textra. it gives me an option to send to email in a text format.
    11-20-2018 05:55 PM
  4. Velenoso's Avatar
    Backup your Galaxy smartphone to your computer
    https://www.samsung.com/au/apps/smartswitch/getstarted/Android/computer-transfer/
    Use smart switch if you don't have it you can get it at galaxy apps.
    edglock21 likes this.
    11-20-2018 06:07 PM
  1. Why does my Samsung Galaxy Tab4 10.1 display a Low Internal Memory Warning
    By Android Central Question in forum Samsung Galaxy Tab4 10.1
    Last Post: 11-13-2018, 10:21 AM
  2. How to delete pictures from gallery that are backed up on Google Drive
    Last Post: 11-12-2018, 06:55 PM
  3. settings>apps crashes on Galaxy Note 9
    By wulf Alpha in forum Ask a Question
    Last Post: 11-12-2018, 12:47 PM
  4. "Primary Mail Only" Gmail notifications on Gear Sport from Samsung Phone
    By Android Central Question in forum Samsung Gear Sport
    Last Post: 11-12-2018, 12:04 PM
  5. Why is my Android 8.0 system taking up so much internal storage?
    Last Post: 11-12-2018, 12:02 PM
