1. hiennhan12's Avatar
    I have Sprint. And I have these Sprint apps.
    I don't know which ones I should uninstall / or disable? I've disabled some. But there's apps like, Wifi calling and secure wifi app.
    I'm trying keep certain apps from using up battery . But I think the system now that it upgraded to Nougat. Because stuff like Android system stuff are using the most percentage of battery.
    12-25-2018 08:55 PM
  2. Rukbat's Avatar
    An installed app doesn't use battery, only one you run does. Just don't run them.
    Android System is "most of the phone", it's not a Sprint app.
    12-25-2018 10:36 PM
  1. Why my phone is not ringing at 4AM alarm
    Last Post: 01-16-2019, 06:11 PM
  2. How can I return google pixelbook i didnt buy
    Last Post: 12-26-2018, 07:17 AM
  3. voice access stuck on lock screen . how do.i get it off to unlock my phone?
    Last Post: 12-26-2018, 05:08 AM
  4. Can i retrieve a deleted playlist i had on Go Music Plus app?
    Last Post: 12-26-2018, 05:00 AM
  5. Why can`t i update my Luxpad Stream9 from KitKat 4.4.2?
    Last Post: 12-25-2018, 10:59 PM
