1. blueGN7's Avatar
    I have photos saved on SD card so after connecting my phone,I select Card/DCIM/Camera & I get a window with all my JPGs & I can drag them to copy onto my computer Hard Drive.
    The problem:
    I cannot change the default order of the long list of photos.
    There are 3 column headings; Name, Date Modified & File Size.
    I want them ordered by date modified.
    Instead they seem to be ordered by name. So when I have several new pix to transfer, I find them difficult to quickly locate.
    I tried clicking or Right clicking on the column headings to see if that changes it but, no.
    01-08-2019 01:34 PM
  2. Rukbat's Avatar
    The date modified is normally going to be the date you copied them to the PC, so that won't do you much good. There are EXIF programs that can modify the file date to be the same as the EXIF date, but you'f have to find one (use Google), install it on your PC, then run it on that folder, telling it to modify all files (*.*). And you'd have to do that on all new pictures (or you could just run it on all again).
    The alternative is to rename the pictures by yyyymmdd<the actual name>, so the name sort would be sorting by date.
    01-08-2019 02:44 PM
  3. chanchan05's Avatar
    You want them ordered by date created, not date modified. Right click on "Date Modified" and turn on "Date Created"
    Laura Knotek likes this.
    01-08-2019 05:42 PM
  4. blueGN7's Avatar
    Thanks for the replies! I already knew that once I moved the pix to my computer they would all have the same date regardless of when I actually took the photo. That is not my issue. Even though it is annoying.
    If I have 100 photos stored on my phone & I take 4 new pix today.
    I want to use Smart Switch to move those 4 new pix to my computer, I do not want to do anything with the old photos.
    Once I open the window showing the folder with all my pix, they are all listed an order by name & NOT ordered by date created or modified.
    Once photos are on my computer, I can change names, change column headings, select how to organize the list, etc. No problem.
    I am specifically talking about when I view the list of photos, still on my phone, using my computer & Smart Switch. It is very difficult to find the new ones that I want to select to move.
    I can click or right click on the 3 column headings & nothing happens.
    Maybe Smart Switch does not work well with Macs?
    01-09-2019 01:28 AM
  5. chanchan05's Avatar
    Oh you're using a Mac. Okay. The right click thing is for Windows. No idea how to do that kind of stuff on Macs.
    01-09-2019 02:15 AM
  6. blueGN7's Avatar
    FWIW, Macs can Rt. click too. I use it all the time.
    01-10-2019 01:11 AM
  7. chanchan05's Avatar
    I meant the right click to show the options for date created etc. The OP already said that doesn't work on her Mac.
    01-10-2019 08:52 AM
  8. blueGN7's Avatar
    I’m the OP & am a man.
    Still no success.
    Today I took 5 new pix & when I went to transfer to my Mac, I found 2 of the new ones in the middle of the list together & 3 several items down the list. IDK how they are organized but it is very annoying I cannot click or Rt. Click the column headings to change the sort order!
    I’m liking Android less & less. (Have other issues I have posted w/o solving.)
    01-13-2019 09:08 PM
  1. Replies: 2
    Last Post: 01-11-2019, 10:38 AM
  2. iPhone to Android
    By iainharwood in forum General Help and How To
    Last Post: 01-08-2019, 11:12 PM
  3. Can we recover photos from Whatsapp (via Bluestacks) after a phone change?
    Last Post: 01-08-2019, 01:11 PM
  4. No sound through bluetooth with google maps
    Last Post: 01-08-2019, 12:22 PM
  5. Google Drive Update files to view offline
    Last Post: 01-08-2019, 12:18 PM
