    I have dump the entire .bin file from an Galaxy S7 edge G935F by chip-off method. I have mounted the .bin file and results the partitions, except userdatas encrypted. Please, any methods to flash the partitions to boot an another s7, the pattern code is knowed thx
    02-04-2019 05:58 PM
  2. Rukbat's Avatar
    Encryption depends on the individual phone, among other things (Like its IMEI number). If you decrypt both phones, then do it all again, then encrypt them again, it should work.
    02-04-2019 08:53 PM
  1. Can't Seem to disable bixby in new Pie Update S9.
    By MissBorgia in forum Samsung Galaxy S9 & S9+
    Last Post: 04-07-2019, 04:49 PM
  2. What icon is this. It appeared after a recent update to the LG G6
    By Android Central Question in forum LG G6
    Last Post: 02-19-2019, 10:40 AM
  3. How to check my cell phone id brand new samsung galaxy s7 or refurbished
    Last Post: 02-04-2019, 07:02 PM
  4. Can't Seem to disable bixby in new Pie Update S9.
    By MissBorgia in forum Samsung Galaxy Note 9
    Last Post: 02-04-2019, 05:21 PM
  5. What icon is this. It appeared after a recent update to the LG G6
    Last Post: 02-04-2019, 04:51 PM
