    I am trying to turn on fingerprint lock. When I click on "+ Add Fingerprint" I immediately get an error message saying "Make sure that the Home key is clean and dry, then try again". When I click OK on the message it closes out of the add fingerprint screen straight away.
    it is very much clean and dry.
    02-19-2019 10:18 AM
  2. belodion's Avatar
    Is it a new device?
    02-19-2019 11:28 AM
  3. Rukbat's Avatar
    Take a Q-tip and rubbing alcohol and gently wipe the Home button. If that doesn't fix it, if it's new try to get the phone replaced. If it's not, learn to live with it. That type f fingerprint reader (I had the same problem with a Pixel 2) is prone to what you have happening. It may clear up by itself. (After about 6 months of not working, I was able to add a fingerprint - without having done anything.)
    02-19-2019 03:10 PM
  1. I can receive phone calls and hear but cannot answer back
    Last Post: 02-23-2019, 05:53 PM
  2. Replies: 1
    Last Post: 02-19-2019, 04:18 PM
  3. How to prevent the upgrade to android 9 on my Nokia 8?
    Last Post: 02-19-2019, 10:11 AM
  4. is there an app to make thumbnail contact sheets from videos?
    Last Post: 02-19-2019, 10:10 AM
  5. Unistall galaxy s9 software
    Last Post: 02-19-2019, 09:39 AM
