    There should be "Phone Visibility" showing in "connections" between "Bluetooth" and "Data Usage" It has disappeared. Can you help?
    02-24-2019 02:33 AM
  2. Everyday Dyce's Avatar
    The same thing has happened to me. The option disappeared just a few minutes after i got two S10+ last week. I did network and factory reset, nothing helped. Samsung even remote controlled and couldn't figure out.
    05-20-2019 10:38 AM
  3. Everyday Dyce's Avatar
    I figured out what the problem was after hours and hours of trying everything. You have to install the SmartThings app. As soon as you do that, the option reappears.
    05-20-2019 06:58 PM
  1. Samsung Galaxy Watch Active
    By Jewels81 in forum Samsung Smartwatches
    Last Post: 02-24-2019, 09:37 PM
  2. 4G data not working in note 9 in LTE BAND 1 (2100)
    By Android Central Question in forum Samsung Galaxy Note 9
    Last Post: 02-24-2019, 12:36 PM
  3. Replies: 1
    Last Post: 02-24-2019, 03:14 AM
  4. My Notification sounds are not muted when my earphones are plugged in??
    By Android Central Question in forum Xiaomi Android Phones
    Last Post: 02-24-2019, 12:19 AM
  5. Call Disconnects Automatically in my oppo f1s after few seconds
    Last Post: 02-23-2019, 08:28 PM
