1. JStarr2019's Avatar
    I have a Samsung Galaxy S7 that is in airplane mode. I lost the phone. Is there some way to turn off airplane mode so that I can call the phone and have it ring?
    Thanks in advance for any help you can give. It's much appreciated.
    J
    03-02-2019 11:05 AM
  2. Rukbat's Avatar
    You can\t turn airplane mode off remotely because ... it's in airplane mode. It won't hear the command to turn it off. (Receivers radiate signal too, so they're off.)
    03-02-2019 11:24 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! Was wi-fi turned on in Airplane Mode? If so, you should still be able to locate it using Find My Device or Find My Mobile. Otherwise, you'll just have to hope somebody finds the phone and contacts you based on any emergency information you entered into it. If you didn't enter any emergency contact information, then looks like you'll have to do a remote wipe and find a new phone.
    03-02-2019 01:45 PM
  1. Why the phone makes a call while im on message app
    Last Post: 03-02-2019, 01:51 PM
  2. Why is my phone camera showing blank?
    Last Post: 03-02-2019, 01:44 PM
  3. Is there a way to completely lock my phone?
    Last Post: 03-02-2019, 01:43 PM
  4. Replies: 1
    Last Post: 03-02-2019, 01:05 PM
  5. 3/1/2019 is there a way to change my text color back
    Last Post: 03-02-2019, 10:55 AM
