    So I just started having this issue on my Galaxy s7 Edge today.
    The first thing that happened was that my phone kept trying to pull up Google Assistant, interrupting anything I was doing, and asking my to turn it on. It got to the point that I just flat out disabled the Google App.
    But now, every time I try to push home it tries to activate my Echo, and when I push the power down button, nothing happened unless I force a restart.
    Any insight?
    03-13-2019 01:58 PM
  2. Rukbat's Avatar
    You remapped your buttons somehow?
    03-13-2019 02:45 PM
  3. zoey Thomas's Avatar
    Any insight?
    Me:
    The same thing is now happening to me. How did You fix it? What Was the cause?
    04-17-2019 11:10 PM
  4. Golurk's Avatar
    Not quite sure about the power button, but if you long press/press too long on the home button it will activate Google Assistant which you might’ve changed to Amazon Alexa. Accidentally remapping buttons is probably the most likely event.
    05-01-2019 12:24 PM
  5. cathalkenny's Avatar
    Any insight?
    I have the same issue after updating my phone is there any solution
    07-25-2019 08:16 AM
  1. How do I get Google Discover back when long pressing home button
    By Android Central Question in forum Samsung Galaxy Note 8
    Last Post: 03-25-2019, 03:09 PM
  2. Google cutting back on hardware (and Pixelbook) efforts
    By jabaa in forum Google Pixelbook
    Last Post: 03-23-2019, 10:10 PM
  3. S10 (not S10+ or E) battery life
    By pootyash in forum Samsung Galaxy S10 & S10+
    Last Post: 03-16-2019, 07:07 AM
  4. Why is my keyboard not coming up on my Google Pixel after update?
    By Android Central Question in forum Google Pixel & Pixel XL
    Last Post: 03-15-2019, 11:00 PM
  5. can not get downloaded song on my phone into my ringtones
    Last Post: 03-13-2019, 02:28 PM
