1. ccciii's Avatar
    The phone rings, but when I try to answer there is nothing there. This usually happens at 0:07 or 0:08 on the call time. When I press the red call end button, there is no response on the screen. I have to press the button on the right of the phone to clear the screen. The caller typically hears continued ringing when I try to pick up. Of course, this only happens sometimes for the last couple of weeks
    03-18-2019 10:33 AM
  2. Rukbat's Avatar
    Instead of tapping the green button, try sliding it.
    03-18-2019 01:05 PM
  3. ccciii's Avatar
    That's not it. The ringer stops on my end, and the screen looks like the call is live. However, the call is still "ringing" on the sender's end.
    03-19-2019 01:42 PM
  4. B. Diddy's Avatar
    Welcome to Android Central! Does this also happen in Safe Mode? https://support.t-mobile.com/docs/DOC-28008.
    Are you able to make calls without difficulty?
    03-19-2019 09:56 PM
  1. Is there a calendar that will let you make notes on individual reminders
    By Android Central Question in forum Android Apps
    Last Post: 03-27-2019, 01:07 PM
  2. Bluetooth headphone sizzle on android
    Last Post: 03-18-2019, 01:15 PM
  3. Replies: 1
    Last Post: 03-18-2019, 12:56 PM
  4. Fat palms and getting accidental screen touches ( samsung edge touch)
    By Indecisi0n in forum Samsung Galaxy S10 & S10+
    Last Post: 03-18-2019, 09:31 AM
  5. Use Samsung A5 2016 screen ''to save'' A5 2017 model
    By Trab82 in forum Samsung Galaxy A5
    Last Post: 03-18-2019, 08:25 AM
