    I have an S7 edge.
    05-30-2019 01:25 PM
  2. joeldf's Avatar
    I have an S7 edge.
    Delete the account that it's syncing to.
    Depending on which OS version you have, I'd look in Settings, then Accounts. Some account types sync several things (email and contacts), and you have the option to turn off the ones you don't want if you can edit the account.
    05-30-2019 03:13 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! Is this a calendar synced from your Google account?
    06-01-2019 11:47 PM
  1. Samsung Gear S3 Frontier - After ONE UI update
    By 7h3d34f0n3 in forum Samsung Gear S3
    Last Post: 06-12-2019, 11:26 PM
  2. Voice/Data on Sprint
    By dwain77 in forum Moto G7
    Last Post: 06-06-2019, 12:00 AM
  3. Microsoft Office Calendar Appointments Won't Sync With S9+ and Vice Versa
    By Android Central Question in forum Samsung Galaxy S9 & S9+
    Last Post: 06-05-2019, 11:07 AM
  4. Do I have to switch back to iphone? Gmail notification doesn't work
    Last Post: 05-30-2019, 12:40 PM
  5. Synced Android Pie to Windows 10 issues
    Last Post: 05-30-2019, 12:12 PM
