    After attempting to flash a rom with odin3 the SM-G935T is stuck in a boot loop. Upon exiting the download menu the phone is stuck in a "Installing update" loop. I cannot access the recovery menu. All I can do is access the download menu. The Odin flash failed. Any insight will be appreciated.
    06-01-2019 05:07 PM
  2. mustang7757's Avatar
    Which Odin you used? And have download the correct firmware ?
    06-01-2019 08:30 PM
  3. Tc3r3s's Avatar
    I used the latest Odin. I used this https://androidfilehost.com/?fid=745425885120745969 firmware. This was the firmware that got me stuck.
    06-01-2019 09:28 PM
  4. B. Diddy's Avatar
    I moved this to the S7 edge Rooting/ROMs forum for more specific traffic.
    06-01-2019 10:14 PM
  5. Rukbat's Avatar
    Boot to download and try Odin again. If it still fails, try getting your firmware from SamMobile.
    09-07-2019 03:29 PM
  6. mustang7757's Avatar
    That's a firmware , that link
    What's Odin number you used?
    And use the correct firmware!
    09-07-2019 03:40 PM
  1. Replies: 13
    Last Post: 06-12-2019, 12:27 AM
  2. App updates not showing in Google Play Store
    By Android Central Question in forum OnePlus One
    Last Post: 06-01-2019, 04:13 PM
  3. Replies: 1
    Last Post: 06-01-2019, 02:29 PM
  4. How do you change the text message bubble color on samsung galaxy 8 plus
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 06-01-2019, 11:46 AM
  5. How do you change the text message bubble color on samsung galaxy 8 plus
