OK, so I take my phone out of my pocket to answer it and I get the message 'Touch input blocked To prevent this from happening again, check if the proximity sensor is blocked', while I'm trying to see who is calling. Now I've seen other posts with this problem, but the answer is always given to uncheck 'block accidental touches' in display settings. The reason this setting is checked is to keep phone from accidentally turning on in your pocket. My question is, can you keep the message from popping up without turning off the setting? ( I've got it on for a reason )
06-18-2019 01:07 PM
