Galaxy Note 10 Deal: BOGO at Verizon!
  1. Berenost's Avatar
    Title says it all. Phone info in attached pictures. Have had the phone for a couple years now. To the problem:
    Phone started acting weird, so I did a factory reset, wiped media partition cache multiple times to be sure. Mounted \system and rebooted. Worked fine for a couple days, then WHILE USING THE PHONE, the screen when ultrabright. Swiped down, and Outdoor mode was on, and auto brightness is gone. I can literally find only 1 post on the web about this. Some sort of residual code from the S6 models. Everyone says to factory wipe but I don't want to be doing this every couple days.
    Any ideas on how to fix this?
    Thanks in advance.
    *Should mention that since getting the phone, this is the first real problem I've experienced.
    Auto brightness replaced by outdoor mode.-screenshot_20190717-104059_cpu-z.jpgAuto brightness replaced by outdoor mode.-screenshot_20190717-104054_cpu-z.jpgAuto brightness replaced by outdoor mode.-screenshot_20190717-104050_cpu-z.jpgAuto brightness replaced by outdoor mode.-screenshot_20190717-104042_cpu-z.jpg
    07-17-2019 09:49 AM
  2. mustang7757's Avatar
    Thanks in advance.
ID:	305549Click image for larger version.
ID:	305550Click image for larger version.
ID:	305551Click image for larger version.
    Hi,
    I like to know a little more about your issue with auto brightness and out door mode?
    07-17-2019 04:11 PM
  3. Berenost's Avatar
    Sure, ask away, though I don't know what other information might help. Included phone info here.
    Attached Thumbnails Auto brightness replaced by outdoor mode.-screenshot_20190717-223205_settings.jpg
    07-17-2019 09:34 PM
  4. mustang7757's Avatar
    Hi, what do mean by out door mode ?
    07-17-2019 09:35 PM
  5. Berenost's Avatar
    The area circled in the picture below USED to be Auto Brightness (On/Off), but that's gone, and it's been replaced with Outdoor Mode (On/Off).
    Outdoor mode was a feature of the Galaxy S6 EDGE and Edge+, from what I gather.
    My only idea is that the S7 firmware was written overtop of the S6 firmware using it as a base, instead of a fresh write, and the Outdoor Mode was hidden, but not removed.
    This Outdoor Mode occupies the same feature base as Auto Brightness, and apparently has a bug that swaps them out.
    I'm looking for a way to swap them back/get rid of Outdoor Mode ALTOGETHER, and return my Auto Brightness option to me.
    Attached Thumbnails Auto brightness replaced by outdoor mode.-screenshot_20190718-070749_email.jpg
    07-18-2019 06:14 AM
  6. mustang7757's Avatar
    I see, didn't remember that as a option been awhile since I had the s6edge, but in settings then display do you see auto brightness?
    07-18-2019 10:35 AM
  7. Berenost's Avatar
    Nope still just outdoor mode.
    07-20-2019 12:22 PM
