Re: SM-G935T to SM-G935T ??
Seems like this is an international device with TMobile firmware flashed to it. Perhaps there are services such as wifi calling with TM firmware. It's probably OK to flash the TM firmware although I would be inclined to use smart switch to check for upgrades first as opposed to using Odin.
The F is Exynos (so is the build number), so the Exynos TWRP should work. (There's Android 9 for most countries for the F.)
If he's not using TMobile as his carrier, he doesn't need TMobile firmware.
OP can't download the TMobile firmware , it's not compatible with Exynos and snapdragon not compatible with Exynos... OP has the international version and firmware
In that case the international version can be flashed to the phone
