03-28-2020 04:44 PM
51 123
tools
  1. androidloveryes's Avatar
    ok...so what can i try to solve this?
    i seem to have a soft different from the pic you showed
    you talk about cache. the cache of what exactly?
    03-23-2020 12:15 AM
  2. mustang7757's Avatar
    I will explain more tomorrow , it late here for me .
    03-23-2020 12:31 AM
  3. mustang7757's Avatar
    Clear cache , I was referring to is the apps cache ,data, force close ..only if it's not giving notification, but you say it is when not in airplane mode .
    03-23-2020 04:07 PM
  4. androidloveryes's Avatar
    in device maintenance i clicked on storage and clared like this
    <a href='https://www.casimages.com/i/200323104658150676.jpg.html' target='_blank' title='Mon image'><img src='https://nsa40.casimages.com/img/2020/03/23/200323104658150676.jpg' border='0' alt='Mon image' /></a>
    just to be clear on airplaine mode.
    when airplaine mode is off it means that data is on and when like this, if im in the bathroom and my phone rings in kitchen and someone leaves a message , i will see a voicemail notification when i come back from bathroom so that is ok but when i go to sleep i put airplain mode on to redue emf exposition. if someone leaves a voicemail during this time and that i turn airplane mode off when i wake up, i do not receive any notification even if someone has left a voice mail. that is on my edge 7
    i tested with old d850 lg phone and with the same coditions, he will show me a notification wich tells me the provider is set ok and does its job.
    when i click apps show system app, i see this ,4 phone app. <a href='https://www.casimages.com/i/200323104656783700.jpg.html' target='_blank' title='Mon image'><img src='https://nsa40.casimages.com/img/2020/03/23/200323104656783700.jpg' border='0' alt='Mon image' /></a>
    i see force stop is this what you talk about ? how would force stop help ?
    03-23-2020 04:39 PM
  5. mustang7757's Avatar
    [IMG=1080x1920]https://nsa40.casimages.com/img/2020/03/23/200323104658477153.jpg[/URL]
    Yes force stop is there right corner but go in storage there and clear data,cache then force close
    03-23-2020 04:55 PM
  6. androidloveryes's Avatar
    how do force close is going to change thing or help?
    03-23-2020 05:18 PM
  7. mustang7757's Avatar
    It's not, because it works as it should with no air plane mode
    03-23-2020 05:22 PM
  8. androidloveryes's Avatar
    hi i really do not understand your explanation hahaha
    you suggest for a solution to force stop but you say it will not help.
    can you explain? .
    i notice you put a few words in you recent answers . would there be a time more suitable for you to help me cause on one hand im french so it helps if the explanations are more exaustive and on the other i feel confused about you suggestion and how it will contribute to solve the prob.
    sory for misspelling some words,
    cordially
    eric
    03-23-2020 05:40 PM
  9. mustang7757's Avatar
    can you explain? .
    cordially
    eric
    That was early on in the beginning, so what I want to say is airplane mode you WONT get notifications or calls ...When it's NOT in Airplane Mode You will
    03-23-2020 06:11 PM
  10. androidloveryes's Avatar
    ok but from what i understand, when i am in airplaine mode or when the phone is simply off and someone leaves a voice mail, when i switch my phone to airplaine mode off, the phone should tell me : heywhile you were offline someone left you voicemail so check it out!
    my ok phone does show me these "stored voicemail notification" and my edge 7 does not. it is supposed to let me know as i turn my phone on that i received a voicemail while my phone was off. isn't it ?
    03-23-2020 06:31 PM
  11. mustang7757's Avatar
    Because in airplane mode it has no data or signal
    03-23-2020 06:33 PM
  12. androidloveryes's Avatar
    yeah of course i dont expect to receive a notification if my phone is off or airplaine mode is on... what i expect from it is that when i turn it on, it lets me know that i received a voicemail while i was off.
    03-23-2020 06:40 PM
  13. mustang7757's Avatar
    No it wont , I tried this
    03-23-2020 06:52 PM
  14. androidloveryes's Avatar
    well why does my old phone can do it why before on my edge it was able to do it
    on top of this it would not make sense cause all people reconnecting to data would not know that they received a voce mail?
    03-23-2020 07:13 PM
  15. mustang7757's Avatar
    I have newer Android phones so maybe something Google changed through Android updates on newer phones
    03-23-2020 07:32 PM
  16. androidloveryes's Avatar
    hum are ou saying that not being notified that i received a voicemail while my phone was off on in airplain mode is normal nowadays to summarise?
    03-23-2020 07:36 PM
  17. mustang7757's Avatar
    I take that back , I was able to get a notification after I took my Note 10+ out of air plane mode , sorry was testing my other phones and couldn't on my pixel 4xl , ...so seems certain phones
    03-23-2020 07:45 PM
  18. androidloveryes's Avatar
    ok, agreeed.
    so .... lets go back to the situation , i cleared data but not force stop. how can that help?
    mustang7757 likes this.
    03-23-2020 07:49 PM
  19. mustang7757's Avatar
    ok, agreeed.
    Yes , by the way pixel got it but was delayed.
    Clear cache,data,force stop , it resets the phone app incase a glitch
    03-23-2020 08:06 PM
  20. androidloveryes's Avatar
    ok once i will have clicked on force stop, will there be a button to tell it to run again? cause i click force start on a Tmobile app and it stayed gray, not turning back!
    03-24-2020 12:27 PM
  21. mustang7757's Avatar
    No, just test again
    03-24-2020 12:33 PM
  22. androidloveryes's Avatar
    hii just cleared data cache force stop and made a test, the problem is still there.
    what else can i try
    03-28-2020 03:41 PM
  23. mustang7757's Avatar
    Hi, you can going settings>reset network
    03-28-2020 03:43 PM
  24. androidloveryes's Avatar
    hum what kind of network am i trying to reset?
    here are my choices in setting
    03-28-2020 04:42 PM
  25. androidloveryes's Avatar
    and here is what i see under connectionshttps://nsa40.casimages.com/img/2020/03/28/200328105001525629.jpg
    03-28-2020 04:43 PM
51 123
  1. During a phone call on Galaxy s9, i cannot use the Hold call button.
    By IKR ROGUERAZIAL in forum Samsung Galaxy S9 & S9+
    Last Post: 02-08-2020, 09:31 AM
  2. How do i find out if my phone is hacked
    Last Post: 12-05-2019, 06:21 PM
