    My s7 edge screen, when the screen is off is turning on same as receiving a notification. An empty blue border cube icon, shows up on the black background which says ( content hidden). Once you turn on, the screen, the notification is not shown. Have tried multiple different applications for notification logs, none of them detects it. Have disabled secret folder and hide notification content, just so I am able to see what is it all about( did not help). Only shows up on turned off screen every 30 to 40 minutes. Fully up to date software. No idea what it is, but it is annoying. Does not triggers the notification light only the egde lighting. Any help/idea what might be and how to solve it?
    01-05-2020 05:07 PM
  2. mustang7757's Avatar
    Can you post a screenshot of it?
    https://forums.androidcentral.com/sh...d.php?t=413366
    I'll leave a link to register so you can communicate here, as a guest account u cant .https://forums.androidcentral.com/sh...d.php?t=409154
    01-05-2020 07:52 PM
  3. belodion's Avatar
    We can go no further if you don't respond.
    01-06-2020 04:20 PM
  1. Full Screen Gestures - More Screen Options
    By Sammuel1973 in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 01-06-2020, 04:47 PM
  2. How do i get android 10 on my Galaxy A50?
    Last Post: 01-05-2020, 04:36 PM
  3. Help needed on Samsung S7 Dual Sim functionality
    Last Post: 01-05-2020, 03:24 PM
  4. Replies: 4
    Last Post: 01-05-2020, 02:31 PM
  5. How do I change boot order in bios on my fusion 5
    Last Post: 01-05-2020, 01:59 PM
