Good day, developers.
I have installed a custom rom called Resurrection Remix running Android 7.1.2 on my Samsung A5 2015. I found a feature, under Configurations, where I can change the system animations for the entire operating system, and also prevent apps from overriding transitions.
All the animations are set to 'Default' at this time, but I desire to change the system animations to look like the Samsung Galaxy S7 Edge. For example, under 'Activity open animation', it can be set to:
Default
Fade
Slide in Right
Slide in Left
Slide in Right (No fade)
Slide in Left (No fade)
Slide in Bottom
Slide in Top
Translucent
Grow in (Top)
Grow in (Center)
Grow in (Bottom)
Grow in (Left)
Grow in (Right)
Can anyone indicate, the specific system animations of the Samsung Galaxy S7, please?
System Animations
Activity open animation ?
Activity close animation ?
Task open animation ?
Task open behind animation ?
Task close animation ?
Move to front animation ?
Move to back animation ?
Wallpaper open animation ?
Wallpaper close animation ?
Wallpaper intra open animation ?
Wallpaper intra close animation ?
Animation Duration ?
ListView
ListView animation ?
ListView interpolator ?
Thank you very much in advance.
Default
Fade
Slide in Right
Slide in Left
Slide in Bottom
Slide in Top
Translucent
Grow in (Top)
Grow in (Center)
Grow in (Bottom)
Grow in (Left)
Grow in (Right)
System Animations
ListView
