1. Wilbur H's Avatar
    Good day, developers.
    I have installed a custom rom called Resurrection Remix running Android 7.1.2 on my Samsung A5 2015. I found a feature, under Configurations, where I can change the system animations for the entire operating system, and also prevent apps from overriding transitions.
    All the animations are set to 'Default' at this time, but I desire to change the system animations to look like the Samsung Galaxy S7 Edge. For example, under 'Activity open animation', it can be set to:
    Default
    Fade
    Slide in Right
    Slide in Left
    Slide in Right (No fade)
    Slide in Left (No fade)
    Slide in Bottom
    Slide in Top
    Translucent
    Grow in (Top)
    Grow in (Center)
    Grow in (Bottom)
    Grow in (Left)
    Grow in (Right)
    Can anyone indicate, the specific system animations of the Samsung Galaxy S7, please?
    System Animations
    Activity open animation ?
    Activity close animation ?
    Task open animation ?
    Task open behind animation ?
    Task close animation ?
    Move to front animation ?
    Move to back animation ?
    Wallpaper open animation ?
    Wallpaper close animation ?
    Wallpaper intra open animation ?
    Wallpaper intra close animation ?
    Animation Duration ?
    ListView
    ListView animation ?
    ListView interpolator ?
    Thank you very much in advance.
    02-07-2020 03:35 AM
  1. How do I reset system update?
    By G Hardy in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 02-09-2020, 08:06 AM
  2. Replies: 5
    Last Post: 02-07-2020, 03:22 PM
  3. System UI not working
    By Android Central Question in forum Samsung Galaxy Note 8
    Last Post: 02-06-2020, 05:29 PM
  4. System UI not working
    Last Post: 02-06-2020, 03:31 PM
  5. Galaxy S5 not updating Android system
    By TheloniusAndroid in forum Android 5.0 Lollipop
    Last Post: 02-06-2020, 01:14 PM
