1. g_patkar's Avatar
    Hi All, the trusty S7 was a bit slow with tonnes of apps and download data - so I wiped the phone data via the Android system recovery menu (Home, Up and Power - followed by Wipe data/factory reset).
    Phone was wiped and then rebooted successfully ("Welcome to Android" - Selected English as my language, followed by joining my Wifi network). After joining the Wifi the screen froze. I then tried a soft reset with the Volume Down+Power key - however the phone just went off and did not restart.
    At the time the phone was a bit warm (Guessing due to the charge + wipining activity). Battery power was 100% when the phone started after the wipe and was in setup mode. I have left the phone to charge all night, but cannot power it on by either Power only, Volume down+power or Volume Up+Home+Power.
    I really need to get the phone back up and running (If i can turn it on). ANY ADVICE or PC troubleshooting steps would be much appreciated!
    01-09-2021 10:51 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Try pressing and holding Power and Vol Down for about 20 seconds. Then wait a few seconds, and then press Power for about 20 seconds -- does anything happen then?
    01-09-2021 11:30 PM
  3. g_patkar's Avatar
    Nothing. The screen just stays off so I have no idea. ALso the phone was working fine before the wipe. It also started after the wipe in the setup mode when it froze on joining Wifi.
    01-10-2021 12:13 AM
  4. B. Diddy's Avatar
    It may be that the slowdown prior to the reset was a warning sign of impending hardware failure. You might have to bring it to a repair shop, if you still want to salvage the phone -- but the cost might not be worth the value of the phone.
    Sometimes it helps to press and hold Power even longer, for like 60 seconds -- give that a try.
    I'll see if @mustang7757 has any other thoughts, since he's one of our resident Samsung wizards.
    mustang7757 and J Dubbs like this.
    01-10-2021 12:48 AM
  5. mustang7757's Avatar
    Go back in recovery and factory reset once more
    01-10-2021 01:07 AM
  6. g_patkar's Avatar
    Thanks @B. Diddy. No luck @ 60 seconds!
    Thanks @mustang7757 ... Under no circumstances does it allow me to power on. I am sure the wipe was successful as the phone restarted and was going through the setup (Language, Wifi setup, where it stopped ; im guessing followed by the Google account input).
    Are there anyways to boot the phone from the PC. My phone is not rooted! Please help. Thanks again.
    01-10-2021 03:22 AM
  7. mustang7757's Avatar
    Oh , doesn't start , let it charge connected to computer for few hours see what happens. If still nothing most likely battery went .
    01-10-2021 09:15 AM
  1. My phone still not receiving Android 11
    By KitKat Gaming2008 in forum Samsung Galaxy S10e
    Last Post: 01-13-2021, 09:37 PM
  2. I have a samsung galaxy A11. There is a blue circle by some contacts names.
    Last Post: 01-10-2021, 08:06 AM
  3. Replies: 2
    Last Post: 01-09-2021, 07:06 PM
  4. [GAME][4.2+] Flashcards for Kids. Animal sounds and puzzles
    By Prospektoro in forum Android Games
    Last Post: 01-09-2021, 02:22 PM
  5. The bottom half of my S7 is gray
    Last Post: 01-09-2021, 12:31 PM
