1. Sulejman Hadzic's Avatar
    Im actually without a phone right now, but if it's worth wating for the galaxy s7 edge, then I'll wait. Is it?
    I really want the galaxy s6 edge plus, but will the galaxy s7 edge be better? Better battery? Better camera?
    Is it worth waiting? Or should I go with the galaxy s6 edge plus?
    02-01-2016 02:40 AM
  2. Jaycemiskel's Avatar
    Battery life will be better. You're already this close, I'd wait
    02-01-2016 02:52 PM
  3. getbretweir's Avatar
    if you can wait I'd wait, but we've only been given rumors ... nothing is official until Feb 21, then it'll probably be a few weeks til it's available
    02-01-2016 07:25 PM
  4. anon(9408097)'s Avatar
    Such a bad time to be phoneless. The S7 won't come out till March. Of course it will launch a bit earlier. Maybe 21st February. I'd say wait.
    Although I would never be able to do that myself.
    02-02-2016 01:19 AM
  5. Mad Dad's Avatar
    I would definitely wait it out.
    02-02-2016 07:50 PM
  6. stevevd's Avatar
    If you can wait, then wait. Especially if the rumours that it will have expandable memory are true.
    02-02-2016 08:29 PM
  7. cen89's Avatar
    I think you should wait if you can, of course if you want to have the lateles and greatest from samsung and i think we all do...
    02-02-2016 10:19 PM
  8. psteve2005's Avatar
    I'd wait. If you don't like the new one, or don't want to pay the money for it, then bear in mind the current model will be cheaper then.
    02-03-2016 02:44 PM
  9. rf-harris's Avatar
    It is all up to you that you can wait for s7 edge to release or not because the general thought is that it would be better than s6 edge plus. At the moment if you have an s6 edge plus then you would surely have one of the best phones available in the market at the moment.
    02-04-2016 06:23 AM
  1. About to grab a used Verizon Note 4...Any issues I should check for?
    By bubbarob1978 in forum Samsung Galaxy Note 4
    Last Post: 02-04-2016, 05:06 AM
  2. Why can't I reset my Samsung Galaxy Tab 3?
    By AC Question in forum Samsung Galaxy Tab 3
    Last Post: 02-01-2016, 12:49 PM
  3. Replies: 1
    Last Post: 02-01-2016, 12:45 PM
  4. Replies: 0
    Last Post: 02-01-2016, 01:49 AM
  5. Best Option for VPN Access to Server Shares
    By James Blight in forum Android Apps
    Last Post: 02-01-2016, 12:40 AM
