1. jsiddle2025's Avatar
    can anyone with some scientific background explain how this pipe filled with water will cool the phone?
    will it be effective?
    I am knowledgeable on how liquid cooling loops work in a gaming PC, but with no reservoir or pump, how does this work?
    02-29-2016 12:17 PM
  2. N4Newbie's Avatar
    Gee, I don't know...
    I would hardly call this "liquid cooling." More like a simple heat sink/pipe designed to draw heat away from the processor and dissipate it elsewhere.
    Samsung's Galaxy S7 is the first smartphone to feature a clever liquid cooling system » TechWorm
    http://www.techtimes.com/articles/13...stem-works.htm
    ironass likes this.
    02-29-2016 12:26 PM
  3. sfla99's Avatar
    It uses the same technology as PC builds.
    02-29-2016 12:32 PM
  4. N4Newbie's Avatar
    Sorry, but no.
    Real liquid cooling as used in PCs pumps actual liquid (water or antifreeze) through tubes and passes it through a radiator similar to one in your car. For example, Water Cooler, Water Cooling, Liquid Cooling System - Newegg
    02-29-2016 12:41 PM
  5. Wizzy's Avatar
    It's passive liquid cooling technology, as opposed to active systems in PCs that have more room and power for fans and radiators. It should be able to spread the heat better over the phone's surface area. Of course, the proof's in the pudding!
    Posted via my LG G4
    02-29-2016 02:05 PM
  6. osta.doc's Avatar
    Wonder if that tube could break when I drop my phone? Could be a problem?
    02-29-2016 02:12 PM
  7. Cakefish's Avatar
    The solution to that is not dropping your phone ;P
    02-29-2016 02:14 PM
  8. N4Newbie's Avatar
    I'd doubt it. It is a flat copper tube sealed at both ends.
    02-29-2016 02:27 PM
  9. N4Newbie's Avatar
    Posted via my LG G4
    I would like to see some evidence that it functions better (let's say, at least 10 - 15% better) than a simple copper heat sink of approximately the same dimensions and mass. Otherwise it's just hype.
    02-29-2016 02:29 PM
  10. LeoRex's Avatar
    I wouldn't say its hype. That would be a lot of time, money and effort invested if that was the case. They've been talking about using systems like this for some time now. If wasn't more effective than a more simple copper heat sink, they'd just stick to the simpler heat sink.
    Laura Knotek and droidman2177 like this.
    02-29-2016 02:40 PM
  11. N4Newbie's Avatar
    You're right; I was just in a mood.
    For the OP: https://en.wikipedia.org/wiki/Heat_pipe
    02-29-2016 03:08 PM
  12. osta.doc's Avatar
    Now there's an idea.......lol........never thought of that.
    02-29-2016 03:10 PM
  13. jschu22's Avatar
    Yeah, Samsung hasn't ever created and hyped up a new feature that ended up being discarded in subsequent devices...
    03-01-2016 01:06 PM
  14. LeoRex's Avatar
    Well, that happens quite often. But it's also a little different. Once a particular hardware feature, especially something something that has a significant impact on both the physical layout and thermal performance, makes it into production, it's there for a reason. And I'm glad to see it... I'd rather have a phone dissipate heat better than have it thermally throttled. The S6 registered the highest temperature of any phone on the market last year, hitting 120F under heavy load on a spot near the camera module. You take all that heat and thin it out, and you get the keep on the ol' go-pedal a lot longer before you have to lay off to keep things from getting too hot.
    ironass likes this.
    03-01-2016 01:26 PM
  15. ironass's Avatar
    The S6 was running on the Exynos chipset because the Qualcomm 810 was even hotter and turned out to be a total disaster for Qualcomm in the end. They have now pushed out the 820 chipset which is supposed to run a lot cooler but, it would seem, not as cool as Samsung would like...
    Galaxy S7: Samsung racing to fix overheating Snapdragon 820 [Updated]
    20blks likes this.
    03-01-2016 01:39 PM
  16. LeoRex's Avatar
    Shame that the early press caused so many problems... my 6P has an 810 and I have zero heat issues nor any throttling headaches. But the S6 still ran hotter than the any of the early 810 phones, never mind the ones that came later in the year. Samsung must have recognized this and saw the need to do a more thorough job with thermal management next time around. These new processors may be more thermally efficient, but they aren't going to run any cooler.
    03-01-2016 02:39 PM
  17. DJCBS's Avatar
    This isn't really liquid cooling. Just like the Microsoft Lumia 950 doesn't have it either. These are heat pipes. Sony has been using them since the Z3+. They work fairly well, but it also depends a lot on the quality of the software optimization done to the chip.
    If you want to see what these heat pipes are really like, this video of the L950 tears it apart.
    03-01-2016 05:59 PM
  1. Replies: 1
    Last Post: 02-29-2016, 04:17 PM
  2. When I enter the Google account ID in my mobile it didn't accept it?
    Last Post: 02-29-2016, 04:13 PM
  3. Can't load up Google Apps on Marshmallow
    By JustADroid in forum LG G4
    Last Post: 02-29-2016, 03:50 PM
  4. how to get map working in S-Health with Gear Fit?
    By Momchi in forum Samsung Gear Fit 1 & 2
    Last Post: 02-29-2016, 03:06 PM
  5. Anyone getting burst of pictures with just a light tap on screen?
    By isabel95 in forum Samsung Galaxy Note 4
    Last Post: 02-29-2016, 03:05 PM
