06-22-2018 03:46 PM
284 1234 ...
tools
  1. DizWhiz's Avatar
    Deleted
    03-14-2016 06:45 PM
  2. DizWhiz's Avatar
    Android is taking up 30% of mine as well. Is Knox the issue? How does one turn it off?
    Make it so.
    03-14-2016 06:46 PM
  3. saratogag35's Avatar
    Same here.
    Attached Thumbnails Android System using 30% battery-screenshot_20160314-200339.jpg
    03-14-2016 07:04 PM
  4. saratogag35's Avatar
    Knox is using a ton of battery. I see this is for security, should I disable it to get better battery life or is this needed?
    Attached Thumbnails Android System using 30% battery-screenshot_20160314-201109.jpg
    03-14-2016 07:11 PM
  5. Jason Stroud1's Avatar
    I think it's used for enterprise security. It won't let me disable it
    03-14-2016 07:12 PM
  6. allensize04's Avatar
    i can't disable it either. but it is using a lot of battery as well.
    03-14-2016 09:30 PM
  7. stevenkisor1's Avatar
    I have Verizon version. It's letting me down with battery life so far. Any tips?
    I found that Verizon Cloud was set to automatically backup everything EVERY hour. Absolutely NOT necessary for me , nor for most people I would imagine. So I disabled the app. I think it's helping some. But I'm still showing Android System as the largest battery consumer.
    03-14-2016 09:37 PM
  8. Jason Stroud1's Avatar
    I already had that disabled
    03-14-2016 09:38 PM
  9. DizWhiz's Avatar
    I'm on ATT and I can't disable it. I can Force Stop it under settings >application manager but that's it. Says it's used 16% of my battery since last charge which is ridiculous.
    Make it so.
    Jason Stroud1 likes this.
    03-14-2016 09:57 PM
  10. Mrrikki's Avatar
    https://uploads.tapatalk-cdn.com/2016...47b5d095fe.jpg
    Knox is draining the **** out of my battery.
    I didn't turn knox on when I did original set up as I have never needed it.
    03-15-2016 01:13 AM
  11. DizWhiz's Avatar
    I don't think I had a choice. I never created a Knox account so I have no idea why it would be running. There isn't even an actual Knox user app on my phone.
    Make it so.
    03-15-2016 01:42 AM
  12. neflictus's Avatar
    I hope Samsung fixes this bug, as it doesn't seem to be an isolated incident.
    03-15-2016 02:15 AM
  13. dj7_madridista's Avatar
    30% ???? Well, that's odd, and way too much! I have a Moto G and it uses around 5% battery.
    03-15-2016 06:10 AM
  14. Jason Stroud1's Avatar
    It never asked me to turn it on or off
    03-15-2016 06:46 AM
  15. Jason Stroud1's Avatar
    Make it so.
    I bought package disabler pro and disabled Knox and other bloat. Will update with results
    03-15-2016 08:08 AM
  16. scupking's Avatar
    Right now mine says android systems is using 39% with Knox saying it has used 26% battery. Thats crazy...
    03-15-2016 08:27 AM
  17. mz7590's Avatar
    I hope this isnt a thing that everyone is dealing with because it would be a real disappointment
    03-15-2016 08:29 AM
  18. Jason Stroud1's Avatar
    Yeah it's ridiculous
    03-15-2016 08:34 AM
  19. stevenkisor1's Avatar
    Same here, just bought it also. I'm disabling just a few items at a time, (maybe just 1 or 2 per day) to see which ones may be the culprit .
    03-15-2016 08:37 AM
  20. Jason Stroud1's Avatar
    Please report back if you find it
    03-15-2016 08:40 AM
  21. Aquila's Avatar
    There is no set value that the OS should be using. It is relative to the other usage of the device. If you use your screen a lot more, then the OS usage as a % of total will be lower. If you're one who idles a lot and has a lower screen time, then OS will be higher as a % of total. Jason Stroud1's screenshots are perfectly normal because the phone is idling a lot of the time and the screen is barely being used. Mrrikki's screenshot is perfectly normal because the screen is being used over twice as much. Signal strength, type of connection (WiFi, LTE, HSPA, etc), screen on time, GPS activity, wake activity, etc. all have huge impacts on battery life.
    20blks, Maisoumenos and Trees like this.
    03-15-2016 09:12 AM
  22. DaveInFL's Avatar
    Mine seems to be high too, but I did get around 24 hours of battery time yesterday (8 hours of which was sleep time for me) and 4.5 hours of screen on time, which is fine for me. Went I went to sleep I had 10% remaining, which I can live with, but Android System is showing as > 20%.
    03-15-2016 09:13 AM
  23. Almeuit's Avatar
    To be honest ... those stats do not sound bad at all. I really wouldn't worry about the system showing as 20%. Something has to be taking up the battery and as long as it is taking up the battery to the point of just draining it rapidly, well, then really no issue .
    03-15-2016 09:17 AM
  24. Jason Stroud1's Avatar
    That's not true because I have used my phone for a couple hours straight screen on time and the android system was still higher. And also I've seen people with 15+ total hours and 4 hours screen on with lower android system usage. I've used this phone like I've used all the ones before and never has android system consistently been higher than my screen
    Dukins and 562dope562 like this.
    03-15-2016 09:18 AM
  25. motivr's Avatar
    30% standby drain in 9 hours. LOL
    what do you suggest?
    03-15-2016 09:20 AM
284 1234 ...
  1. Replies: 1
    Last Post: 10-12-2017, 09:21 AM
  2. marshmellow or android n
    By steven dawe in forum Samsung Galaxy S5
    Last Post: 03-23-2016, 02:49 PM
  3. android wear disconnects when ever my phone is on charge
    By Naz 1 in forum Android Wear / Wear OS
    Last Post: 03-18-2016, 11:07 AM
  4. cannot pair samsung S5 with malibu 2016 using android auto
    Last Post: 03-13-2016, 02:57 PM
  5. my huawei y330 writes user partion cannot be used again
    Last Post: 03-13-2016, 01:50 PM
