I fully charged and left it unplugged overnight to test battery life during idle (when phone is not turned on, with no apps running in background)
S7 battery drain has nothing to do with the battery itself. it's Qualcomm Snapdragon SoC problem.
No. Nova. Noooooooooooooooooooooooooooooooooooooooooo.
After much dismay and using Nova for over 7 years, I had to let it go. Long story short, Nova Launcher was keeping my phone awake the entire time the phone was on. I am NOT saying that it's everyone's problem, but unfortunately for me and MY phone it was causing my phone not to deep sleep. After removing Nova, I began to setup Touchwiz, my phone rebooted by itself and the phone was super warm. After removing it, my phone now sleeps like a baby. I expect that my massive drain will end. Again this may not be everyone's problem, but for me I had to let it go. Sorry Nova, Touchwiz works just fine for me right now.
Same here, and I'd love to know if this is why I'm getting 2.5-3.5 hours of screen on time vs others 6+. I have wifi set to turn off when asleep, but per gsam, the wifi never shuts off. Something must be keeping my phone awake....I use Nova, would love to know how you figured it's effecting Doze so I can track it on my phone
This thread seems worth reading: http://forums.androidcentral.com/samsung-galaxy-s7/655771-sucky-battery-fix-galaxy-s7.html
How do you determine what prevents the phone from deep sleep?
Right, but how did you figure it's keeping your phone awake? Also, memory usage and battery usage are two different things. If Nova shows under battery stats with some high number, that would be concerning but it usually runs around 2% which is nothing and very much normal. Your battery life may be phenomenal but it's not because you removed it ...
I just checked...Settings-Application Manager-Click on the app. Look at memory. Nova Launcher uses too much memory.
Again, once I removed Nova, my battery has been phenomenal.
Turn the phone off. When the phone is off Hold down the volume up button, Home and Power button while the turn phones back on. Do not release until you see the android logo. It will then boot into recovery mode. You will see the cache wipe there. The volume up and down move and the power button selects the option.Where do I find those settings? Thanks
