1. Krzywy777's Avatar
    Hi
    My partner's S7 has a weird issue. Always On Display shows all fonts/clocks in bright pink/red. I have S7 edge and everything is fine, font and clock is white as it should be. Any idea why it is like that? It is brand new phone and it's like that from when it was taken out from the box.
    04-01-2016 05:29 PM
  2. GadgetGator's Avatar
    Does the display look pinkish in general or only on the always on display? I guess you could try a factory reset and see if it improves anything.
    04-01-2016 08:48 PM
  3. Krzywy777's Avatar
    Everything is fine. Just the AOD is affected. Did not try the factory reset yet. May be the only option.
    04-02-2016 11:52 AM
  4. Krzywy777's Avatar
    This is how it looks like
    04-02-2016 11:56 AM
  5. GadgetGator's Avatar
    That is really weird. Yeah I think you should reset it. Something is not right. It's almost like a Samsung theme has been applied somehow changing the appearance. But that cannot be the problem since it came out of the box that way.
    04-02-2016 03:05 PM
  6. Krzywy777's Avatar
    Just did the factory reset but it is still exactly the same:-(
    04-02-2016 04:06 PM
  7. Darnell0216's Avatar
    By any chance did you install a theme? Some themes on the S7 have customized AOD settings. If you changed themes, switch back to the default and see if that helps.
    On the other hand, try a free theme with a custom AOD and see if the color/design changes to see if maybe there's a deeper issue.
    04-03-2016 04:00 PM
  8. Krzywy777's Avatar
    Hi
    Nope, I did not install anything. It was like that straight out of the box and even after factory reset.
    04-03-2016 04:39 PM
  9. Krzywy777's Avatar
    Just installed a theme which changes AOD.
    Below images show how it should look like (blue) and how it looks on my phone.... guess.... pinkish...
    04-03-2016 04:59 PM
  10. Krzywy777's Avatar
    What it should be:
    04-03-2016 05:00 PM
  11. GadgetGator's Avatar
    I don't know what is going on with that phone, but if a factory reset didn't fix the problem and a new theme didn't fix the problem, then I think it needs to be exchanged for a new one.
    04-03-2016 07:32 PM
  1. disable side buttons on Priv
    By davidca41 in forum BlackBerry Priv
    Last Post: 08-20-2016, 09:19 PM
  2. Wifi calling not turning on?
    By Stephen33 in forum LG G5
    Last Post: 06-08-2016, 12:24 AM
  3. Replies: 2
    Last Post: 04-03-2016, 10:58 AM
  4. Camera Won't Switch on Samsung Mega 6.3
    Last Post: 04-01-2016, 04:56 PM
  5. Replies: 1
    Last Post: 04-01-2016, 04:42 PM
