A
AC Question
Just bought a new Sansung s7 and my fingerprint lock will not let me in! I have not even seen the contents yet! How to change back to factory ? Help!
You can remote unlock the phone via android manager online, this is a great way to access and unlock a device when you either have an issue like this or forget your password/ pin.
Welcome to Android Central! Does it even ask you for your backup password? When you try to unlock using your fingerprint, does it say that your fingerprint isn't recognized?
No just wait 30 minutes
Are you the original poster on this thread, or joining the discussion? Just wondering, because the title thread mentions 60 minutes, not 30 minutes.
Well after seeing the OP's forum name and the fact that they never replied.... yes you've been trolled.
Samsung find my phone can remotely unlock your phone, IF you have it set up.I´m facing same situation. I locked my S7 with finger print and when the phone reinitiated I had to place my password.The issue is that I forgot it. I log in android manager online and I try to unlocked the phone but the only option is to lock it.
Is there any way to unlock the screen without reseting the phone and losing the information?
The OP posted as an unregistered guest in the Ask A Question forum, which is why it shows up as "AC Question, Guest." The person I replied to had just registered, and seemed like she might be referring back to the original post, so that's why I was asking if she was the OP (and had subsequently signed up for the forums). I see this behavior a lot. So I don't think it was necessarily trolling.
Mine too! It's asking for a password (which I never set up) and won't let me in. I tried to reset the password with the android device manager and got this message: "Since Google has verified that a screen lock is already set, the password won’t be needed."
I called T-Mobile and they just say to d a hard reset, but I don't want to lose all my pictures and apps!
