1. jcp007's Avatar
    When I selected the WiFi connection, my device would select the connection which I assumed is the default. I have Comcast as my ISP. The modem is dual band. I have logged into both bands. There appears to be an open public xifinity wifi. My GS7 would always be on one of the secure bands when I turned wifi on. Now, I have to select it. Is my GS7 the issue?
    04-10-2016 04:42 AM
  2. jcp007's Avatar
    Connection is stable. When I tried it again, the original secure network connected with no intervention on my part. But subsequent tries didn't produce a consistent result in terms of which network connection was chosen when WiFi was enabled.
    04-10-2016 07:05 AM
  1. Messenger: auto correct default out dated for the S7?!!!
    By AC Question in forum Samsung Galaxy S7
    Last Post: 04-12-2016, 03:33 PM
  2. N910V Screen mirroring question
    By sandaddict in forum Samsung Galaxy Note 4
    Last Post: 04-11-2016, 01:13 PM
  3. SD Card Question
    By Shujinko in forum Android 6.0 Marshmallow
    Last Post: 04-11-2016, 09:19 AM
  4. How connect my Android tv box to server after factory reset
    Last Post: 04-10-2016, 03:07 PM
  5. Samsung Galaxy s7 edge Wifi Issues
    Last Post: 04-09-2016, 10:03 PM
