1. gbilton's Avatar
    just got my S7 and use hangouts for my SMS over the stock Samsung app and I changed the notification sound to something different and still get the stock hangouts notification even though the setting say it is not that. I also changed the settings through the phone to the same sound in the messages setting and nothing. is there some other setting in a place i'm not looking?
    04-16-2016 07:40 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Are you using a preinstalled tone or a custom tone? When you go into the Hangouts settings, be aware that you can change the tone for your SMS messages as well as the Hangouts messages. To change your SMS tones, are going to the Hangouts settings and tapping SMS (as opposed to your account name under Account Settings)? If you tap the account name, that will change the tones for Hangout IMs (not SMS).
    04-17-2016 02:07 AM
  3. gbilton's Avatar
    its a custom ringtone set the same tone for both and still get the stock hangouts sound even changed the sound under notifications> messages in the phone's settings. the sound plays in the selection screen without problem both in hangouts and in phone settings. baffling
    04-17-2016 06:28 PM
  4. B. Diddy's Avatar
    Is the custom tone saved on the microSD card or in Internal Storage? Make sure you have it saved in the Notifications directory in Internal Storage.
    04-17-2016 07:02 PM
  5. gbilton's Avatar
    there is no sd card in the phone
    04-17-2016 08:07 PM
  6. B. Diddy's Avatar
    Try going to the App Manager, select Hangouts, and Clear Cache/Data. Then open it again and see if the problem persists. If it does, also try a cache partition wipe: https://support.t-mobile.com/docs/DOC-24999
    04-17-2016 10:12 PM
  7. jhnnyblze2000's Avatar
    I'm having the same issue. I've tried all this and still doesn't work. Even tried uninstalling and reinstalling hangouts and still doesn't work.
    04-19-2016 08:06 AM
  8. gbilton's Avatar
    I've tried all of the above and still nothing
    04-21-2016 02:10 PM
  9. gbilton's Avatar
    found a workaround Hangouts suggested switching to google's messenger so i tried it and now custom SMS sounds work for me! YAY
    B. Diddy likes this.
    04-25-2016 04:43 PM
  1. I want to Debrand my Samsung Galaxy S6 Edge + SM-G928A
    By thelittleleto in forum Samsung Galaxy S6 edge+
    Last Post: 10-04-2016, 01:45 PM
  2. MMS Not working
    By justplainme0485 in forum Android 5.0 Lollipop
    Last Post: 04-17-2016, 07:28 PM
  3. Notification Management
    By ctvette2003 in forum Ask a Question
    Last Post: 04-16-2016, 04:36 PM
  4. Replies: 0
    Last Post: 04-16-2016, 03:11 PM
  5. Why are my emails not loading on my phone?
    Last Post: 04-16-2016, 03:00 PM
