2 Attachment(s)
Need help identifying battery draining process "10322"
Hello everyone,
There is a process of my phone named "10322" that is draining my battery. Does anyone know what process this is?
The following screenshot were taken a morning after my phone was sitting idle on my night table. Thanks
Attachment 224982Attachment 224983
Re: Need help identifying battery draining process "10322"
Have you deleted any apps recently? I recall seeing somewhere that an app is assigned a process number when it is deleted. Probably a restart should fix everything.
Thanks. I'll charge my phone fully, restart, let it drain a bit in idle, and then report back
Its a deleted app. Once your battery stats reset, it will go away.
Posted via the Android Central App using my badass Galaxy S7
Thanks guys! I recharged my phone to full and have been using it throughout the day. I'm now at 40% and the process hasn't appeared and my battery drain appears normal.
