1. Shehram Majid's Avatar
    Hello everyone,
    There is a process of my phone named "10322" that is draining my battery. Does anyone know what process this is?
    The following screenshot were taken a morning after my phone was sitting idle on my night table. Thanks
    Need help identifying battery draining process "10322"-screenshot_20160418-111305.jpgNeed help identifying battery draining process "10322"-screenshot_20160418-113220.jpg
    04-18-2016 12:35 PM
  2. f308gt4's Avatar
    Have you deleted any apps recently? I recall seeing somewhere that an app is assigned a process number when it is deleted. Probably a restart should fix everything.
    Shehram Majid likes this.
    04-18-2016 01:32 PM
  3. Shehram Majid's Avatar
    Thanks. I'll charge my phone fully, restart, let it drain a bit in idle, and then report back
    04-18-2016 02:07 PM
  4. williams448's Avatar
    Its a deleted app. Once your battery stats reset, it will go away.
    Posted via the Android Central App using my badass Galaxy S7
    04-18-2016 07:59 PM
  5. Shehram Majid's Avatar
    Thanks guys! I recharged my phone to full and have been using it throughout the day. I'm now at 40% and the process hasn't appeared and my battery drain appears normal.
    04-19-2016 12:11 AM
  1. Empty battery image on display no power up
    Last Post: 04-19-2016, 01:33 AM
  2. [S6] Samsung game tools missing pls help
    Last Post: 04-18-2016, 12:16 PM
  3. Nexus 6P battery life reduction
    Last Post: 04-18-2016, 11:25 AM
  4. do i need my sync on all the time to receive emails?
    Last Post: 04-18-2016, 11:13 AM
  5. Replies: 2
    Last Post: 04-18-2016, 10:39 AM
