Cakefish
Simply pressing the volume button once when the phone is ringing will mute an incoming call. No need to unlock the phone, or even the screen to be on.
hahahah except that the phone will ring first before you can flip it over. If you're in a meeting or place where you need to be quiet, you're already screwed at that point. Some people want to be able to mute the phone without unlocking and then holding down a rocker switch. And then making sure all 4 volume levels are muted just in case
I haven't run into this issue. I simply hold and it goes to vibrate and everything is silence -- regardless of the other volume bars.
"Media" volume doesn't get muted in that case though. And you still have to unlock the phone, which is annoying when you just want to quickly mute the phone with one hand without looking at it
