1. bluefalcon555's Avatar
    I just changed from an HTC One M9 to a Samsung Galaxy S7. My HTC would flash the notification light indefinitely any time I had an active notification (until I addressed it and cleared it). With the S7, if the screen is on, the LED doesn't light up, which is a problem if I am in full-screen mode and the notification bar isn't showing. If I missed the initial notification, I am out of luck until I exit the full-screen mode.
    Is there any way (a setting or an app) that I can get the LED to come on when the screen is on? (This would also be helpful because I often charge the phone when it's on, and I would like the light to inform me when it's fully charged.)
    Thanks in advance!
    05-23-2016 04:27 PM
  2. SpookDroid's Avatar
    Not from stock settings. Not sure if LED-modification apps like Lightflow would do that, though.
    05-23-2016 04:34 PM
  3. bluefalcon555's Avatar
    I didn't find any joy with Light Manager, and what I read of Light Flow was the same.
    05-23-2016 04:38 PM
  1. Tmobile screen stuck.How do you fix it?
    Last Post: 07-14-2016, 10:38 PM
  2. Screen is yellow
    Last Post: 06-02-2016, 04:18 AM
  3. Pie chart and menu icons stuck on bottom of screen
    By Thanny in forum Samsung Galaxy S5
    Last Post: 05-24-2016, 11:08 PM
  4. Replies: 1
    Last Post: 05-23-2016, 04:19 PM
  5. How Google is Laying the Foundation to Kill Rogue Background Services
    By quelquehomme in forum Legacy Android & Other OS's
    Last Post: 05-23-2016, 04:16 PM
