How do I get the detailed graph for battery usage on the S7? I just got the phone on Sunday and I seem to be draining about 1.5-2% per hour just sitting at night or at my desk at work. I'd like to be able to see the full graph like my other phones. Those I just tap on the battery graph and it shows things like cell signal, wifi, awake, etc. I keep tapping my graph on the S7 and nothing! Is it there? My Moto X Pure is running 6.0 and it still comes up.
Also - is there a way to quickly get to the battery stats vs. tapping the gear icon and then battery? The MXPE I just tapped on the battery after pulling down but there is no battery on the S7, just the gear icon and quick menu.
Lastly, is 1.5-2% per hour seem normal? It's higher than my MXPE running 6.0.
I have everything "on" just like my Moto. BT, Wifi, AOD (had the Moto version on too and that was an LCD screen so lit up more), etc. I dont want to have to turn things on and off all the time, the phone needs to just work as I use it mainly for work and need a lot of that on almost all the time.
** before I get the comment, yes I can charge it every night and normally do with my phones, I left it off the charger since it is brand new and I wanted to check battery usage while in my 14 day trial period **
