my 100% factory original G930V S7 has just today began having major problems. I have never had any of the following issues until today, I have not installed any updates (at least I never agreed to install any updates).
- battery drain, even in ultra power saving mode battery is draining extremely fast, ~10-15% in 30 min of standby
- phone running extremely hot at all times
- wifi will not turn on, just displays "turning on..."
- bluetooth will not turn on, go into bluetooth settings and moving the slider to on, close out the screen and come back and its back to off, never actually turns on
Does anyone know if there were any Samsung Updates pushed that may have been auto-installed? I've already checked and force-stopped the Gear VR service (I have never used Gear, and do not have Oculus installed) and that's not the problem. I have also already gone through and removed any apps that updated in the past 48 hours (identified via Addons Detector).
Battery view simply shows Android System using up the overwhelming majority. I've cleared cache as well.
I am still on 6.0.1 / G930VVRU2APE1, have been avoiding updating in case I decide to root.
Also trying to avoid a factory reset.
Has anyone else had this problem?
